Spider V Remote use with Spider V20
jkpalmer
Are there any users of the Spider V Remote with the Spider V20 that can a good explanation of how to use the app with Apple MacOS.
I can't find a good explanation of how to load presets, save the original samples in the app or anything else that would help manage custom amps and cabs.
Line 6 Support is not much help, referring me to a link that really doesn't say much.  YouTube is not much help either.
 Help apreciated.
-jP
  • 1 month later...
Hi Jeff,
  • To use Spider V Remote with your Spider V20 on Mac:
  • Install Spider V Remote v2 for Mac from Line 6.
  • Connect amp via USB; no extra driver needed.
  • Edit presets in Signal Flow or Editor and Save Tone → Spider V20.
  • Backup presets via Save Tone to Disk or import/export .l6p files.
  • For custom amps/cabs, use the Cloud to import presets, then edit/save.
  • 2 weeks later...
I have found that in both Mac OS and Windows the software just hangs when you try to change presets with the arrow key near the top middle.  Double clicking on any preset directly just lets you rename it.  However, if you treble click on a preset in the list it will load and your amp will play it.  You can save these presets, or any new ones you make, to your local computer or to the cloud using the load/save button.
I'd almost given up as I was unable to traverse down the list due to the hanging, but when I found that a treble click (I think) on the actual preset worked I was on the road. It may still hang when you select it but I generally find that the first few selections work OK so if you are happy to sit on one preset you should be OK.
  • 2 weeks later...
Yeah on the bottom left it says “Tones” press it then press “Spider V” and it will give you every preset available, and on the top right corner you’ll see a box with a arrow pointing up, press it to save the preset on your V20 and everything that you edited with the app will be saved even when you turn it off and you decide to turn it back on. There is also a SAVE Button on the amp.
