Lou_B Posted February 21 Share Posted February 21 Why can't I get my wah and volume pedal to maintain consistent states when switching between snapshots?!? I have tried everything!! If im on snapshot 5 and I hard press to use the Wah the purple light comes on and it works fine. But if I switch to the clean snapshot wile the Wah is still engaged then it will completely screw up the state of the volume/wah settings on the clean snapshot. There is no consistency to this behavior at all!! I've tried switching the "bypass snapshot" toggle. I've tried saving between every adjustment. Nothing works. Is this a bug? Or am I missing something? Quote Link to comment Share on other sites More sharing options...
julianhafel Posted March 11 Share Posted March 11 SAme issue here! if i use the wah pedal and them return to use de expression as a volume pedal... the behavior is a complete mess... if you have the expression for volume off.. and move to a different snapshot you will have full volume up of that snapshot... but if you press de to have full volume and return to the snapshot that you cut the volume... them you will have volume off... i think there is a bug... how I resolve it... for copy a new volume block.. but it return to the same behavior after using de wah... so... i guess there is a bug in there. Quote Link to comment Share on other sites More sharing options...
