Helix Stadium Native Routing Help/Confirmation
FenixRizn
I just want to confirm that I am understanding the routing correctly. To stereo process with Helix Stadium Native from within my DAW I have placed (1) instance of Native on a stereo group track. I then add a split path and a merge path, setting the balance of A and B to 100% left and 100% right respectively. I then added mono effect blocks/amp/cabs between the split and merge creating identical effect chains on path A and B. Soloing each left/right track gave me audio for that track only. Also if i understand correctly, I can place stereo effect blocks after the merge such as delay/reverb, and keep the stereo image?  And adding a mono block after the merge will effectively kill the stereo image and sum to mono?
Hope that I'm getting this right. I really wish they would add a stereo button to simplify this process.
