StaffK Posted July 6, 2014 Share Posted July 6, 2014 I sometimes run my old XT through the HD500 for extra sounds but also prefer some of the drives & distortions in the XT. Apart from running from stereo outputs into the 500 Is there any other way to rig these two up so theres no signal or drive/sustain loss, Obvious one would be Pre the other post. Cheers for any advice. Quote Link to comment Share on other sites More sharing options...
NucleusX Posted July 10, 2014 Share Posted July 10, 2014 Sounds like you running inputs and outputs in a serial fashion. The HD500 also has an FX loop you could put the XT in, if you haven't already tried it yet. EG: Guitar > HD500 Input > FX Loop Send (L Mono) > XT Input > XT Outputs (L+R Stereo) > HD500 FX Loop Return (L+R Stereo) > HD500 Outputs > Amp. Then you would need to add an FX block in your HD500's signal chain, assigned to the FX Loop, and set your desired Send/Return volume levels to suit. 1 Quote Link to comment Share on other sites More sharing options...
