TRandolph1957 Posted October 9, 2014 Share Posted October 9, 2014 I have used this method before & it sounds great. My questions are for the specific settings that work best through my rig with this method. 1.What should the correct output setting be for 4 cable method? ( I have been using stacked front output setting with single cable method into Mesa head ). 2. What are the recommended FX loop settings be set at ? a. How should I even out the volume difference between the FX loop on & off when using my Amp foot switch? 3. What settings should my mixer settings be in the signal chain ? 4. Since I am not using stereo set up should I make changes in the pan settings A & B ? 5. Suggested settings & advantages for occasional Amp modeling ? Any other suggestions you can share would be greatly appreciated. Thank you. Right now at practice i just run it through the front of my Mesa Dual Rectifier half stack.. Been awhile since I tried the 4 cable method. This time I want to make sure my settings have been set up correctly. I Have a gig next week & want the best sound my Rig & HD500 can give me. Thanks to My Rock & Roll Line 6 Forum Friends. Timothy Quote Link to comment Share on other sites More sharing options...
bjnette Posted October 9, 2014 Share Posted October 9, 2014 You could just stick with how you been using it. It is never a good idea to start changing things around just prior to a gig or recording studio session. But when you have time; 1 Try them all including lowering the high shelf and focus.. 2. Question 3 answers 2/2a.you have to adjust the FX return to match the off volume. 4. Not needed as the outs will sum. 5 Not for the gig Quote Link to comment Share on other sites More sharing options...
