Spider Mkii 100w Valve Switches Presets On Its Own...
1 reply to this topic
#1 mizzy63
mizzy63
  • 4 posts
  • Registered Products:4
Posted 30 July 2013 - 06:10 PM
Im using my MkII with a shortboard and an external Line 6 pedal which I assigned as the volume pedal, and the pedal on the shortboard as wah and pitchglide. Problem is every so often it switches back to the volume pedal on shortboard. I'll be in middle of a gig and the volume will jump thru the roof and look down to see the volume pedal has jumped back to the shortrboard!! No idea what is causing this....HELP!!!!
#2 napynap
napynap
    Iknowathingortwo
  • PipPip
  • 284 posts
  • LocationPalmdale, CA
Posted 04 August 2013 - 07:39 PM
Use the SV MkII Edit app and connect everything the way you have at the gig (MIDI too so the computer can recognize the SV). See if you can duplicate the problem by stepping through patch changes, and check the app for the volume settings for both pedals. Maybe one patch you are using still has the volume assigned to the shortboard. I used this technique to disengage volume control for the shortboard pedal for all my patches, it's just to risky on a gig if that pedal accidentally gets moved.
