Relay g10s wireless showing connection between guitar and pedalboard Relay g10s wireless showing connection between guitar and pedalboard
$50 off
The Easiest Guitar Wireless System—Ever
save on the g10s
g10s plugged into guitar and close up of pedalboard
Save Now
The Relay G10S Wireless is the easiest guitar wireless system ever created, and for a limited time, you can enjoy wireless freedom at a special lower price. The Relay G10S Wireless leaves your pure guitar tone unaltered and integrates right into your pedalboard. Save today!
band jumping while playing with g10s band jumping while playing with g10s close up
Cut the cord, and unlock your creativity! Connect to your amp or pedalboard without the limitations of a cable. Use it live, at home, at rehearsal, or wherever you play. Relay G10S wireless is as easy to use as a conventional guitar cable but without the limitations.
g10s plugged into guitar with soundwaves to an amp g10s plugged into guitar with soundwaves to an amp close up
pure guitar tone
Relay G10S provides 24-bit uncompressed digital audio from input to output, and features a wide dynamic range, delivering consistently excellent signal quality throughout. Relay G10S has an extraordinary 10Hz-20kHz frequency response, so you’ll hear the entire spectrum of your sound, even when playing instruments with extended ranges.
Features
  • Simple plug-and-play operation means no setup required 😃
  • Worry-free performance with up to seven hours play time on a single charge
  • Wirelessly connect to your pedalboard, amplifier or direct to the PA system
  • Uncompressed 24-bit audio and wide 10Hz-20kHz frequency response maintain every nuance of your core guitar tone
  • Use with any and all of your guitars, active and passive pickups alike
  • Enjoy wireless freedom with no interference, with a large line-of-sight range (up to 130ft/40m)
SAVE $50
Relay® G10SII
Digital Guitar Wireless System
$269.99
$219.99
close up of g10s
