gianlucanostro
    5
Everything posted by gianlucanostro
  1. Hi, thanks. The PAD setting there isn't in the HX Stomp.. I'm wrong? I read somewhere that I need to use the line input, correct? How I can do it?
  2. I'm playing with the Clapton strat with active pickup (Mid boost active), could be the reason? Tomorrow I'll be at home and I can try with different Strato
  3. Yes, HXSXL. I'm trying with GarageBand and Reaper Preset attached SRV.hlx
  4. Hi guys! thanks. I'm able to create a clean tone. The issue is mostly as soon you add a simple overdrive (ie 808). It should be possibile to record a track with the DAW and with a good sound, right? What is the input pad? I'm using a strato with single coil. About the headphone, I'm using Audio-Technica ATH M50.
  5. Hello, bought 2 days ago a HX Stomp XL. It's very amazing but I don't understand why using the headphone every patch sounds very very bad. It's seems that everything is distorted but not in the "right" way. You cannot identify the single notes... basically, cannot be listened! :) The same think happens if try to record with a DAW so the issue could not be the headphone. I think that it needs to be configured in some way to avoid that, any suggestions? Thanks!!
