kenmac1 Posted October 23, 2014 Share Posted October 23, 2014 How can you set a HD500X to not select modelled guitars on patches, but to go to the actual Mag pickups?When I am looking through the options I do not see that offered, and it is not in the big manual I downloaded as far as I can see either. Quote Link to comment Share on other sites More sharing options...
Charlie_Watt Posted October 23, 2014 Share Posted October 23, 2014 Wrong forum. Move this to the HD forum. Quote Link to comment Share on other sites More sharing options...
kenmac1 Posted October 24, 2014 Author Share Posted October 24, 2014 NO this is the right forum. I'm using it with a HD500X, so the settings need to be done in the HD not the guitar itself. You create the patches in the HD, and part of that process if using a variax is to set which guitar sounds you want selected. None of that (as far as I am aware) is done on the actual guitar as the patch on the HD is what stores all that information, not the guitar. With my old original Variax models it was easy, there were no mag pickups, so every sound was emulated, but the newer JTVs allow you to use Mags, so there must be a setting inside the HD to make the JTV Mags select on patches instead of the emulations. Quote Link to comment Share on other sites More sharing options...
kenmac1 Posted October 24, 2014 Author Share Posted October 24, 2014 Sorry I thought it was the HD forum. Quote Link to comment Share on other sites More sharing options...
jandrio Posted October 25, 2014 Share Posted October 25, 2014 ...How can you set a HD500X to not select modelled guitars on patches, but to go to the actual Mag pickups?... alternative a: set input 1/2=variax mags alternative b: set model<>"Dont force" (ie whatever model but not "Dont force"), disable modeling on the jtv 'n save preset. alternative c;just disable modeling on the jtv 'n save preset (have not tried this out). prerequisite 4 both is vdi usage. Quote Link to comment Share on other sites More sharing options...
