frankieconsoli Posted January 9, 2015 Share Posted January 9, 2015 I've had a consistent problem with my X2 since I bought it where the input jack on the transmitter constantly comes loose giving me intermittent cut outs. Since this unit is well out of warranty could someone give me a schematic or at least just a description of how to hard wire this thing? I was going to strip the 1/8" connector off the input wire and solder it directly to the board because that's literally the only problem I have with these units. Quote Link to comment Share on other sites More sharing options...
gstew Posted January 10, 2016 Share Posted January 10, 2016 I know this is a year old post but thought I would chime in since I have a few of these units. I have found that eventually every stock X2 guitar transmitter cord, 1/8" TRS jack end, will eventually start making noise; cutting in and out. So, I tried a cheap hosa style molded plastic 1/8" TRS plug, then cut off the other end and put on a mono 1/4" guitar plug to go into my guitar. Can't remember which wire I soldered together at that end but I did follow the original cord's example. For some reason, a cheaper cord with the plastic molded one-piece strain relief would work great on every unit I have. To keep the cord from pulling out during a live performance, I simply use a strip of duct tape to keep the jack plugged into the transmitter. Sounds hokey, but it totally cured the problem. Quote Link to comment Share on other sites More sharing options...
