IDEA SCALE- GLOBAL EQ and FX display control
bjnette
Hiya guys,
First of all Kudos to Line 6 for continuing  support and improvement of the POD HDs! Well Done Line6
I was inspired to put this up after the Looper FS5 idea from radatats
If you edit via the onboard controls you'l notice an inefficiency.
Most of the EQs and FX require cursor and knob 4 to adjust the parameter value.
It must of been an oversight at the time as the remaining display knobs are not utilized except for the Amp and cab sub menu.
This has probably been requested already as it is fairly common sense and with the Global EQ I thought it is never too late!
Your welcome to vote it up.
Cheers
http://line6.ideascale.com/a/dtd/EQ-controlled-by-all-display-knobs/688232-23508
