Black Pete ( Townsend) amp patch
Indianrock2020
I've downloaded many patches for my 500x and had very good luck.  For this new vintage amp I thought I'd try creating a patch.  If you have time take a look at this -- I'm definitely not through with it.   The order of the effects may not even be right.  Looking for a mildly crunchy rhythm tone on single-coil pickups.
http://line6.com/customtone/tone/977325/
Boost Comp>Volume Pedal>Noise Gate>amp>mixer>Digital Delay (off)>Analog Delay w/mod>
Room reverb>Graphic EQ
The amp is set fairly middle-of-the-road except presence and mids reduced some.  Shure 57 off axis on 2x12 Blackface cab with low cut brought up some and Res Level reduced some.
I don't even use the volume pedal so far, just keep it all the way down.
