Master14 Posted May 16, 2015 Share Posted May 16, 2015 Because the Manual is somewhat sparse in information, it there a way to play straight through to my amp and bypass the Firehawk? I use a 4 cable hook up. I have an outstanding amp and would like to be able to switch back and forth between amp and Firehawk. Quote Link to comment Share on other sites More sharing options...
gshamusphoto Posted May 17, 2015 Share Posted May 17, 2015 Because the Manual is somewhat sparse in information, it there a way to play straight through to my amp and bypass the Firehawk? I use a 4 cable hook up. I have an outstanding amp and would like to be able to switch back and forth between amp and Firehawk. I have done tests with my Matchless amp and find that if you select no amp in the clean amp choices it is the same as running straight to the amp from the guitar. I am not sure if it is "tru bypass" as they say but I don't notice a tonal change for this setting. I use it for most of tones and then use some of the Marshall amps for heavier stuff. 2 Quote Link to comment Share on other sites More sharing options...
