carl1000 Posted May 18, 2015 Share Posted May 18, 2015 So I am using a GCX Ground Control to control a POD HD Pro. I have an expression pedal plugged in to the GCX pedal board. It then controls the Expression values set up in the POD Pro. Works great. But...If the pedal is heel down ("0"), then I pick a program that has the EXP pedal enabled in it, when I switch to that patch it acts as if the pedal is at 100% (toe down). I have to bring to pedal to 100% THEN back to 0% for the value to be "0" or toe down. Is there a setting to make the "default" pedal setting to be heel down? It is strange as the pedal is heel down which means the CC# value is "0"! But when I go to the patch it acts as if it is "127"??? Thanks for any help. Quote Link to comment Share on other sites More sharing options...
CipherHost Posted May 18, 2015 Share Posted May 18, 2015 Just wondering if you tried saving the patch with the heel down? Quote Link to comment Share on other sites More sharing options...
carl1000 Posted May 18, 2015 Author Share Posted May 18, 2015 I did not. I will try that. Quote Link to comment Share on other sites More sharing options...
carl1000 Posted May 18, 2015 Author Share Posted May 18, 2015 That didnt help. I disconnected the MAC and saved the preset heel down. Great until I go to another preset then come back to that one. Even with the heel down it acts as if it is toe up or 100% when I come back to that preset Quote Link to comment Share on other sites More sharing options...
carl1000 Posted May 18, 2015 Author Share Posted May 18, 2015 Called Line 6. So when using generic expression pedal with the HD Pro via MIDI....that is just the way it is. Quote Link to comment Share on other sites More sharing options...
