BillMaslanka Posted August 10, 2015 Share Posted August 10, 2015 I have an external expression pedal hooked up to the firehawk for controlling effects in the 'tweak' mode. It seems that once assigned to an effects block, I can't use it on any of the other effects blocks. I'd like to run two delays at once and control the mix volume of both at the same time with the expression pedal, but can only figure out how to do one or the other. Can someone please let me know if the firehawk can do this and if so, how? Thanks! Quote Link to comment Share on other sites More sharing options...
mcbeddall Posted August 10, 2015 Share Posted August 10, 2015 Your right in thinking you could only control one of the delays unfortunately Quote Link to comment Share on other sites More sharing options...
BillMaslanka Posted August 12, 2015 Author Share Posted August 12, 2015 Thanks for confirming that mcbedall! I have another expression pedal question that I could use help with. When using the Bender (Whammy effect), I can only get the pedal to control the 'mix' parameter. I'd rather have it control the 'position' parameter so I can actually change pitch instead of just mixing in a preset pitch. Is this just how the Bender works in Firehawk or is there someway to assign the pedal to 'position'? Thanks! Quote Link to comment Share on other sites More sharing options...
mcbeddall Posted August 12, 2015 Share Posted August 12, 2015 I haven't used bender yet but I just tried assigning the pedal to control position and it worked first time, I'm guessing you already know this but just in case.. You need to hold your finger down on the position slider until a dialogue box pops up asking if you want to assign tweak to the fx knob , click yes and then enable the pedal using the small slider on the same screen Quote Link to comment Share on other sites More sharing options...
BillMaslanka Posted August 12, 2015 Author Share Posted August 12, 2015 Turns out I wasn't holding my finger on the slider long enough! Thanks again for the help!!! EDIT: I've noticed that the longer I use the app for building my patches, the slower/less responsive it gets. Once I close it down and start fresh, it works fine again until it gradually starts getting slower. I think that was a big part of the problem. Quote Link to comment Share on other sites More sharing options...
