spiderIV75 , get shortboard or firehawk ?
nabulaer
Hello ,
I have the spider IV 75. I am not a performer or doing gigs , I use it has a hobby to play for my self at home.
I am thinking of adding a foot pedal for looping and change of tone while playing. should I get the FBV shortboard MKII or go for the firehawk ?
I understand that by going for the firehawk I basically loose alot of the spider multi effect capabilities , or do i ?
The Firehawk is a stand-alone device, but you could feed its output to your Spider amp - using it in a 'clean' mode, or even combining some sounds.  But it won't act as a switchboard/controller for your amp.
The looper in the SPider is very limited - time of loop, and control-wise.   If you want to use a looper with true functionality, I'd recommend an external looper.
