How to assign foot switch to mute vocals
dannyw13
I'm running both guitar and vocal inputs on separate paths and outputs. Anyone know how I can mute the vocal with a foot switch?
If you have a separate output block I suppose you can do this by assigning the output block to a footswitch, select the "Level" Parameter and then set the "Min Level"  to -120.  You could also add a "Gain" block and use the same procedure.
