gtrnstuff Posted December 4, 2015 Share Posted December 4, 2015 I have read that the total throughput analog in to analog out is 1.8ms. I have read that each send and return has its own D/A A/D conversion. Does enabling any or all of the send/return patch points add to the total latency? TIA Quote Link to comment Share on other sites More sharing options...
mdmayfield Posted December 4, 2015 Share Posted December 4, 2015 I believe that if you use them (thus undergoing a D/A conversion and A/D conversion) they will add 2-ish milliseconds of latency to sounds in those paths. If delay compensation for these paths is included in the Helix, then enabling them may add to the total latency whether you use them in the preset or not. I don't know if that's the case. If there is no delay compensation, then the most important thing to watch out for would probably be comb filtering from mixing the 2ms-delayed signal with the original. It's very hard to notice added latency of 2ms, and depending on the circumstances, is often impossible for humans to detect. Whether the idea of it being there bothers you or not is another matter.... Quote Link to comment Share on other sites More sharing options...
gtrnstuff Posted December 4, 2015 Author Share Posted December 4, 2015 That's what I gathered. From my own research, using my DAW and a "click" as test signal comparing direct path and signal path through various devices, I have discovered that I'm OK with latency up to about 5ms (including the devices and the audio interface) when playing guitar and listening through headphones. More than 5ms, I feel it and get pretty annoyed. My hands and ears telling me different things. Too many years of close mic'd amps with an analog monitor path. So, if I try a Helix, I'll make sure it's a local dealer that accepts returns so I don't incur shipping costs. Quote Link to comment Share on other sites More sharing options...
