Global E.Q. Parameters
Hello, I don't get the meaning of Knob 3 for adjusting the global E.Q.
Knob 1: Band selection
Knob 2: Frequency
Knob 3: ????
Knob 4: Gain
The release notes read:
Global EQ — Global EQ is used for compensating for the wide disparity in acoustic environments on tour or when traveling from studio to studio, and is applied to all setlists and presets. Global EQ features three fully parametric bands plus variable low and high cut filters.
To access Global EQ:
  • Press and hold the VIEW button to open the Setup Menu.
  • Using the four-way, cursor right until you see the Global EQ screen.
  • Turn Knob 1 to select the desired EQ band (Low Cut, Low, Mid, High, High Cut) andturn Knobs 2, 3, and/or 4 to adjust the selected band.
  • To bypass or enable Global EQ, press ENTER.
I think your referring to the "Q". The Q narrows or widens a particular frequency range. You should just try it out, example make a riff and record using the looper then play said riff and then go the GEQ and choose a freq range and completely cut it by turning gain all the way down and then narrow and widen the Q.
I hope I explained that right but by testing like this you can actually hear what kind of effect it has to your tone.
