FIREHAWK FX - PC EDITOR IDEAS
enarf24nilug
Hi guys!
First of all,I know that Firehawk is app bassed device but It gives troubles when teweaking tones at home.It would be nice to release PC editor to tweak tones faster and on stage tweaking will be minimal.
Someone has idea for anroid emulators for PC?
2 ways to manipulate de FH app on you PC :
  • setup a Virtual Machine that emulates Android or IOS. I red attentively all the threads talking about that subject and I did find some people  telling it is running but none saying that it was stable (particularly the bt connection)
  • Use an android UI emulation : it is only displaying on your pc the android UI. You manipulate it with your mouse. But the app is still running on you android device (phone or tab). Depending on the solution you are using, the connection between your pc and your android is either wifi or cable
The most reliable and operational solution is the second one. The only drawback is that you cannot use your pc resources (ie : if you want to use a bitbox running on your PC).
Any other solutions (else than having Line6 doing the port :P  ) ?
Please, once you succeeded in it and you are happy with it, can you tell us the detail of your experience.
I m convinced that could be an appropriate solution for all the FH users asking for a PC version of the App.
Thanks in advance
Bernard
Guys I founded great solution for editing Firehawk on PC.
My solution is screen mirroring my phone on PC!
I'll explain what I did step by step.
1. Install VYSOR addon in your Chrome browser
2. Open VYSOR and install ADB drivers on your PC
3. Connect your phone to PC with your standard charging USB cable.
4. IMPORTANT : Turn on USB debbuging in your phone settings ( Settings - Developer options - USB Debbuging )
5. VYSOR will recognize your device after restarting app and your phone screen will be mirrored on PC.
6. Now you can use your mouse for tweaking tones in Firehawk editor and you can use keyboard from your PC to name and find patches etc...
Please be free to ask if you run into a problem thru installing process!
  • 6 years later...
  • 3 years later...
