Live edit????????
roadsidepicnic
Is your Firehawk running the latest firmware? If the screen briefly says v.1.20 when you switch it on, you're up to date. If not, update the firmware first via usb and a pc.
If you're running v1.20 already, try resetting the unit by holding down the master volume knob and the tap tempo footswitch then switch your Firehawk on. See if that solves it.
