JvBree Posted March 31, 2017 Share Posted March 31, 2017 It would be a pleasure when you can set a tempo at the rhytems in the Spider V60 amp. (Not only the volume) This would be a nice upgrade. Quote Link to comment Share on other sites More sharing options...
pber2025 Posted March 31, 2017 Share Posted March 31, 2017 I'm not sure I understand what you are requesting. There is a tap tempo switch on the amp and with theSpider Remote app you can tap the tempo and/or enter the BPM for time based effects. Unless you mean changing the tempo of the drum loops? If this is what you are talking about then yes I agree it would be nice. However I believe those tracks are recorded drum loops, so changing the tempo is not possible. I guess you could probably find a decent drum machine app to run on a tablet and send that audio via USB to the amp. Quote Link to comment Share on other sites More sharing options...
Guest JvBree Posted March 31, 2017 Share Posted March 31, 2017 Hey...i mean there is no setting for the tempo of the drumloops ob the V60 Quote Link to comment Share on other sites More sharing options...
pber2025 Posted March 31, 2017 Share Posted March 31, 2017 True. As I said they are recorded drum loops, so more or less a wav or mp3 file of a real drummer playing. However you can find a good drum machine apps (loopz or similar) to run on your tablet or smartphone and you can stream this over USB to be outputted by the amp if you want to change the tempo. Quote Link to comment Share on other sites More sharing options...
