Momentary A/B with 2 delays with 100% feedback and different times
Giax1974
Hi Guys,
I was trying to do a momentary A/B, I have used split A/B/,  assigned the split to to my momentary switch, also added both output level parameters from 100-0 and 0-100.
The A/B works well, but the problem:
I am using for A : delay with one time (100% feedback and 100%MIX)
I am using for B, the same delay with other time  (100% feedback and 100%MIX).
When switching A to B, the delay I played before does not reset to cero (because is playing the 100% feedback) it continue playing from the past A/B pressed...keep repeating hidden)
I was trying to setup a effect similar to Bloc Party "Octopus", but something is missing... delays and level are added one time and after, and so on, when switching, all my pre-switched delays keep repeating after pressing the switch like hidden...
Can a Delay be reset to cero after switching???
Here is a link to a video which explains the effect with a Line switcher and 2 delay pedals.
Hope you can help mke figure this out...
Here is the setup with different pedals:
Never mind, I figure it out, by adding both delays to the momentary switch also.
Then:
Added a feedback parameter for each delay (This tell the feedback to shut its mouth!) :
DLY 1 parameter of the momentary position 1 (feedback parameter 100-70), momentary position 2 (feedback parameter 70-100).
DLY 2 parameter of the momentary position 1 (feedback parameter 100-70), momentary position 2 (feedback parameter 70-100).
AWESOME!
