4 cable method & going to P.A AND a poweramp at the same time?!?!
lewisstorer
ok guys so this is my first time trying this setup and I need help understanding if its even possible and if so, how to do it.
So I have:
ENGL E530 preamp
Pod HD Pro
and Im wanting a poweramp.
The HD Pro and the Engl is currently 4 cable method together and then using the ENGL's direct out that includes a cab IR built in > FOH
what Im wanting to do is use the Engl for my main rhythm/solo tone going into a cab on stage with me for good monitoring and at the same time use a built in HD Pro Amp/cab sim that goes to the P.A for the Audience.
Obviously rhythm tone will be dry but lead tone I would need reverb and delay that effects both the side that is my ENGL into a cab, and the other side that is amp sim going into P.A. Is that possible?
Im hoping regards to clean tone I can bypass the ENGL all together and run the same clean patch both into my poweramp>cab and direct at the same time. Is this also possible?
And would the best output mode be studio/direct for the crowd to get the better tone?
Ive been using my Kemper and I know its completely possible with that but I want to have a "Road gig" so I dont over use my Kemper even for small gigs and would rather leave it at home for recording 90% of the  time.
Thanks guys
