geraldbriat Posted December 4, 2017 Share Posted December 4, 2017 Hi, I finally received my digitech trio plus. My configuration is firehawk fx + 2 PA speakers only, no amp. I did a lot of search on this forum and on youtube but I was not able to find a good solution. I made some trials with the trio over the week-end. I guess that the trio needs to have the guitar plug into it directly in order to work properly: guitar --> trio guitar in --> trio fx send --> firehawk guitar in --> firehawk left 1/4 --> PA speaker 1 --> firehawk right 1/4 --> trio fx return --> trio mixer out --> PA speaker 2 Doing so I have the cab emulation of the trio in addition to firehawk :-( Plugging a dummy jack in the trio amp out remove the cab emulation but I don't have anymore the guitar loops in the PA speaker 2. Does anyone find a good solution for that configuration please? Rgds, Gerald Quote Link to comment Share on other sites More sharing options...
dcasciat Posted April 20, 2018 Share Posted April 20, 2018 (edited) You may have already solved this so congratulation because I've also looked around a lot(!) for a similar solution. I'm using the trio+ and firehawk fx as follows: guitar --> trio guitar in --> trio fx send --> firehawk guitar in --> firehawk left 1/4" --> trio fx return then trio amp out -> mixer channel (x) in trio mixer out -> mixer channel (y) in mixer out left/right -> powered monitors 1/2 Yes the trio needs the guitar directly connected to the guitar input so it has a clean signal from which to do its magic, ie create bass and drum parts. The trio+ does not need the amp output to be connected to an amp. Connecting to an amp will color the sound of the firehawk's amp/cab models in a way I don't want. Going from the trio+ amp output to a (good) mixer and then out to speakers mitigates this issue. I use a Mackie 802 VLZ4. It is very clean as far as sound coloration (IMHO). I know a mixer isn't in your set-up but if you can swing it, Mackie makes the 4-channel 402 VLZ4, which is only $99. There are plenty of others but I love my Mackie! happy trails. Edited April 20, 2018 by dcasciat clarify Quote Link to comment Share on other sites More sharing options...
