mastercihan Posted February 6, 2018 Share Posted February 6, 2018 Its charged in dock till green led allways on and its mached with transmeter and sound ok.But when g10t plugged out of insturment green led always flashes as unusuallı has to be off. What should I do for this problem .it also can not get into standbye mode with passive pu guitar when volume down.I suspect microswich doest cut power inside... Quote Link to comment Share on other sites More sharing options...
jbuhajla Posted February 6, 2018 Share Posted February 6, 2018 Its charged in dock till green led allways on and its mached with transmeter and sound ok.But when g10t plugged out of insturment green led always flashes as unusuall ı has to be off. What should I do for this problem .it also can not get into standbye mode with passive pu guitar when volume down.I suspect microswich doest cut power inside... Did you connect it to the Line 6 Updater to see if there is a firmware update available? Quote Link to comment Share on other sites More sharing options...
mastercihan Posted February 6, 2018 Author Share Posted February 6, 2018 I will give it a try... I know some standbye issues fixed by update and wish fix this problem too.. last was 1.04 I remember. Micro swich get close all the time it gets green all the time... if it doesnt close the circuit it cant be powered.i dont even see such problem in g10... I replace tbp 12 s ta4 connector input part by myself but this time it should go to warrenty servise I think... Quote Link to comment Share on other sites More sharing options...
