hx effects routing vs helix routing
backcrackr
i have been searching vids and such all over the net and can't seem to find an answer.  i currently have a helix that i primarily use in a 4cm, and i use some always on effects and some that i stomp box.  with the helix i use the editor and setup the patch, then i assign the stomp to the switch.  can i do the same with the hx?
for example on a helix i may have a volume, phaser, flanger, wah, effects loop, pitch, eq, delay which say the effects loop and volume are always on.  can i set this up in an hx and only assign the phaser, flanger,wah,pitch ,eq, delay to the scribble switches?   if i can do this i think the hx is better as im really only interested in the 4cm effects
thanks
You can assign the scribble strips to anything you want. I run 4cm and my effects loop block for my amp, my effects loop for my outboard effects and whammy block are unseen. I have the whammy set to auto-engage so no need to take up a scribble strip and switch for it. I also think the HX sounds better in the loop than my Helix Floor did.  I think this answers your question.
