Birdcage Posted February 20, 2018 Share Posted February 20, 2018 After updating from factory to 1.30 i''v got horrible background noise on my firehawk device (i'v test all ports, same problem there)... Is there any reason for this? Quote Link to comment Share on other sites More sharing options...
kabirjedi Posted February 20, 2018 Share Posted February 20, 2018 Welcome here ! All effect off? If yes and noise exist:Found industrial band and be happy :) Ok maybe real help: First do factory reset and let's see what's happening. Before FR .BACKUP your presets Quote Link to comment Share on other sites More sharing options...
Birdcage Posted February 20, 2018 Author Share Posted February 20, 2018 Yes, with all effects off - same thing.I'v tried different updates for firehawk - still the same. Another thing is when i'm trying to restore to factory settings - on launch>display i see things like Version of update>>>Restore to Factroy>>>Starting... and then nothing happens, just turning on first preset and thats all... Or this thing means that reset has been successfull? p.s. Moreover on different bank presets - noise sounds something different Welcome here ! All effect off? If yes and noise exist:Found industrial band and be happy :) Ok maybe real help: First do factory reset and let's see what's happening. Before FR .BACKUP your presets Quote Link to comment Share on other sites More sharing options...
Birdcage Posted February 20, 2018 Author Share Posted February 20, 2018 Here you can listen to this... Quote Link to comment Share on other sites More sharing options...
Birdcage Posted February 21, 2018 Author Share Posted February 21, 2018 Installing factory update doesn't helps Quote Link to comment Share on other sites More sharing options...
TriPPleX Posted February 21, 2018 Share Posted February 21, 2018 can you go back to 1.20? Could be a hardware issue, but if it started with the noise after the 1.30 upgrade, I'd say it's the update. Maybe go back, hopefully the noise goes away, then try to update via USB again. Quote Link to comment Share on other sites More sharing options...
Birdcage Posted February 21, 2018 Author Share Posted February 21, 2018 i'v already tried to update prev. versions, still same problem, then i'v tried do this throught my smartphone and same stil... can you go back to 1.20? Could be a hardware issue, but if it started with the noise after the 1.30 upgrade, I'd say it's the update. Maybe go back, hopefully the noise goes away, then try to update via USB again. Quote Link to comment Share on other sites More sharing options...
Birdcage Posted February 21, 2018 Author Share Posted February 21, 2018 Moreover i suppose factory reset doesn't works properly Quote Link to comment Share on other sites More sharing options...
kabirjedi Posted February 22, 2018 Share Posted February 22, 2018 Oh.. Ok then last thing before warranty.Try firmware downgrade 1.20 Quote Link to comment Share on other sites More sharing options...
belacdown Posted March 5, 2018 Share Posted March 5, 2018 A mi también me aparece el ruido de fondo, espero que el servicio técnico de Line 6 nos den una respuesta Quote Link to comment Share on other sites More sharing options...
