Midi Timeout Error
Well....the Monkey may not have permanently bricked my POD but there is still a severe lack of joy here.
The latest drivers/firmware/monkey are still messing me up. EVERYTHING worked just fine before updating.
But NOW, even after solving my POD's "Invalid Code Error 1" bootup message, Line6 Edit no longer works
properly. It recognizes my POD but will not complete sync. And there's nothing wrong with my USB cable,
it's not a USB hub problem.....EVERYTHING worked fine before the update...NOTHING else has changed.
I also tried connecting via MIDI AND USB on three different machines and on three different OS's.
I even tried using Gearbox. It DOES work.....partially. I can send and receive single patches but it still
times out when trying to load the POD's memory. I've tried just about everything....uninstalled/reinstalled
EVERYTHING, rolled back drivers and Java....nothing works. I REALLY wish I'd read all the threads about
this out there BEFORE I made the mistake of updating my POD. I am FAR from alone in this boat.
Everything looks fine in the Monkey but no Line6 Edit:
I'm really getting sick of this BS. I've tried everything. I've successfully re-flashed the 3.01 firmware. The MIDI timeout continued to
occur at exactly the same point timing out at 21%. So I thought perhaps this was being caused by a corrupt tone from the user
library. Sooo, one by one, I loaded the unit with factory patches in GearBox. This caused a change but did NOT solve the problem.
Now the MIDI timeout error occurs at 44%. This happens at EXACTLY the same point whether connected via MIDI or USB and it
happens at EXACTLY the same point on THREE pc's and THREE OS's. It SUCKS not being able to load and save bundles but
least GearBox allows me to edit and save individual patches.....Line6 Edit isn't working at all.
Ok, maybe this will help some other users with this problem. There is DEFINITELY something wrong with Line6's coding.
It's either the current firmware or the drivers. Even tho I loaded my PODxt with Line6 FACTORY patches from GearBox I
was still getting a MIDI timeout at 44%. However, being that it changed from 21% to 44% after loading said patches, it
occurred to me that there must be some compatibility issue between the patches and the software. Now, mind you, I NEVER
had this problem before installing the current update. Soooo I re-flashed the firmware one more time BUT, this time, I allowed
the update to install the factory patches that came WITH THE UPDATE. And GUESS WHAT?? No more MIDI timeout!!
Now that's all well and good provided I NEVER load ANY other patches. But, apparently, some older patches....EVEN THOSE
WRITTEN BY LINE6!!.......are NOT compatible with this version of firmware/drivers.
  • 8 years later...
Hi Cristofe, I am very glad I found your post, although it was almost ten years ago that you posted it. Had exactly the same problem with the BassPODxt MIDI timeout, however, mine stopped responding at 0% all the time. Recently, I found another BassPODxt on eBay at a reasonable price, so I decided to buy that one as a replacement. When it arrived, I checked with Line 6 Monkey and found, that USB firmware and device firmware had to be updated. I started the update process on my Windows 10 PC, and when it told me to switch off and on again the BassPODxt, I did so. To my surprise, the PC reacted with a blue screen shutdown, something that did not happen during normal operation in the last two years. I started the PC again, opened Monkey and it told me, the USB firmware had been updated successfully. There was stll the device firmware to be updated, so I started the update process again. Like before, when asked to switch of and on again the BassPODxt, it killed the PC as before. After starting both, the PC and Monkey again, it reported all updates as done. I then installed an older Java 32bit-version (as described elswhere on this forum) and line 6 Edit. Upon startup, the device was found and connected and all internal tones of the BassPODxt were loaded. Success!
The other BassPODxt (the one with the MIDI timeout error) did still not work, although all firmware was reported to be up to date. Thinking about your post I then re-installed USB and device firmware, this time telling the updater that I would NOT like to keep my modified tones, but to replace them by new originals. As before, after two BSOD shutdowns, I tried again -and voila, everything worked fine. That proves that your findings have been correct and reproducable. Shame on Line 6 for not providing this solution for Line 6 customers on their behalf, officially. Thanks to you!
