Integrating HX Effects into existing pedals questions
lespaulraider
I'm buying a Helix next week. I also want to develop a backup board using an HX Effects along with my Mission Volume pedal and my Liverpool Amp. Sim.
1) If I'm sending my signal to FOH, can I put the Liverpool in the Send/Return to achieve amp simulation in that application?
2) Once the Liverpool is in the HX effects loop, can I move the Liverpool around in the signal chain within the HX Effects?
3) Will my passive Mission Volume pedal work in one of the expression pedal spots as a volume pedal?
4) Can the Mission Volume be moved around as well, or is it assigned as "first pedal?"
Thanks.
