samarchermusic Posted May 22, 2018 Share Posted May 22, 2018 Hi, I'm using hx effects to control my Kemper profiling amp via midi. I'm sending midi clock from the hx (Tx Midi clock is on) . My issue is that the tempo is shifting and not staying put. It does not do this when I set up a midi toggle cc message on a hx switch with all values set to '0'. I believe the issue is to do with the fact the kemper has an in built 'beat scanner' which analyses the tempo in accordance with peaks in your signal detected via playing. This is activated when holding down the kemper tap button. (this is activated when controlled externally on any value from 1-127) ... my hunch is that the in-built hx tap switch is constantly sending a value between '1' & '127' and therefore momentarily and sporadically activating the beat scanner allowing for subtle and sometimes drastic changes to the tempo. Is there any work around for this where I don't have to sacrifice a switch to use as my tap via cc message. The kemper does not have a global 'switch off' for beat scanner unfortunately and so that is not an option. I hope this makes sense. Many thanks. Sam Quote Link to comment Share on other sites More sharing options...
