guitarsan1 Posted June 21, 2018 Share Posted June 21, 2018 I've never fooled around much with the pitch shifters and harmonizers in Helix. In this song at 2:24 https://www.youtube.com/watch?v=IeEA9yuZ2G8 there's a solo which is likely double tracked guitars. However, is there an effect in Helix which could simulate this well? Can you tell what the settings would be and what would work best? Thanks in advance! Quote Link to comment Share on other sites More sharing options...
DunedinDragon Posted June 21, 2018 Share Posted June 21, 2018 You can use the Dual Harmony for that but you'd probably have to use snapshots to control the settings as the first part is just using an octave, but the later parts are in harmony. It sounds like it might have at least on key/mode change so you'l likely need to use snapshots for the changes. Quote Link to comment Share on other sites More sharing options...
