Helix HX External Amp switching issues
anthonybest
I am using a Friedman Naked which has a simple 2 button footswitch.  Channel (tip) and Master Volume (ring).  I have assigned each one of the these to stomp 1 and stomp 2 respectively
When i setup the Helix to change the channel on the Friedman it will change the channel from Dirty to Clean... However when i click it to change it back it will not change.
If i then press the master volume switch (stomp 2) it will then switch the master, and if i press it again it changes both the master volume back to MV1 and then changes the channel back to dirty.
Can someone tell me whats wrong, or do i have a faulty unit?
