Thickchesthair Posted August 5, 2018 Share Posted August 5, 2018 Hey guys, having a problem and can't find a solution for it. I have an HD500x and am just getting back into it after a year or so of it sitting on the shelf. No matter what patch I select, if it has a 2 amp setup, I get no sound from the bottom amp on the screen. A good example of this is in setlist 6, bank 2 there is a Metallica patch. The high gain treadplate works, but if you use button FS2 to switch to the clean tone you get silence. Last night I updated the firmware so that should have done the equivalent of a factory reset. I have checked through my settings and nothing seems relevant to my problem. I have tried using both the left and right 1/4" out, but do the same thing. Any thoughts? Quote Link to comment Share on other sites More sharing options...
Thickchesthair Posted August 6, 2018 Author Share Posted August 6, 2018 Thanks for this. I changed the setting from GLOBAL to PRESET and that didn't change anything, but then I changed guitar input 2 from variax to same and it started working. I thought it was common to have variax as the second guitar input to make it sound better? Has anything changed in the last year or two that changes this? Quote Link to comment Share on other sites More sharing options...
