Helix LT/Helix Edit error code -9123
peterbush
I have been trying to connect my Helix LT via USB to my PC(windows 10, USB 2.0 port) but I am not having any luck.  I ran the firmware update to 2.6 last night on a different computer and have moved it to another computer today to use the Helix edit software but it is not seeing my device.  Window's sees the unit fine, I can select it as a sound device and hear audio through headphones connected to the LT.  The updater and Helix edit are not seeing the unit however, if I move around to different USB ports it will show up in the updater but when I close it and open the edit software it says no device connected.  I have tried moving the USB to different ports while the edit software is open and I finally got the error code -9123, does anyone have an idea of what that might be?  Thanks!
I installed the drivers using the HXedit 2.6 installer per some other instructions that I found and have uninstalled the drivers and reinstalled the drivers multiple times but I am not having any luck.
