Snapshot/Footswitch Controller Behaviour - confirming
larjim
New Helix HX Effects user, doing lots of exploring/trial-and-error.
Quick question on a behavior - I had originally set up a preset related to a song, with a set of effect min/max parameters tied to a footswitch controller for a solo section.
Then decided that I wanted to turn a couple of effect blocks on and off during the song (Chorus/Verse and Solo sections), so decided to use a Snapshot.  Rather than re-doing all the parameter changes as controlled by the Snapshot, thought I would just turn the controller footswitch on in the Solo snapshot, off in the Chorus/Verse snapshot.
When I tested switching between Snapshots however, I noticed that the controller footswitch was not toggling on and off - it stayed in whatever state it was in when I started switching between snapshots.  The effects blocks were toggling on and off as expected.
Re-reading manual, this may be as designed - it does say snapshots can turn effects on and off, trigger commands, change parameter settings, etc.. nothing specific about turning footswitch controllers on or off.
Not a show stopper at all, but wondering if this is expected behaviour/behaviour as designed?
