Seanlava Posted October 19, 2018 Share Posted October 19, 2018 hi everyone, I have a question about customizing my performance view display, for which I could not find an answer in the manual. I was able to change the color of my A footswitch LED to green, But the corresponding label (Dist on/off) stays gray, how do I make the colors match? I would like to customize the color for both bypass assigned switches, and controller assigned switches, if that matters. Quote Link to comment Share on other sites More sharing options...
gabeausiello Posted May 4, 2024 Share Posted May 4, 2024 Hi. Did you ever figure this out? I've run into the same issue with my Helix LT. I had issues on my Stomp XL also, but usually ended up just adding and removing blocks in certain orders and I was able to eventually get it how I wanted. It seems to happen often when you have multiple blocks controlled by one footswitch. I currently only have a splitter controlled by the switch, and have the led set to red, but the block label stays gray. So annoying. Hi. Did you ever figure this out? I've run into the same issue with my Helix LT. I had issues on my Stomp XL also, but usually ended up just adding and removing blocks in certain orders and I was able to eventually get it how I wanted. It seems to happen often when you have multiple blocks controlled by one footswitch. I currently only have a splitter controlled by the switch, and have the led set to red, but the block label stays gray. So annoying. Quote Link to comment Share on other sites More sharing options...
