GiffySquirt Posted October 27, 2018 Share Posted October 27, 2018 Just got the HX Effects today after wanting it since it came out because it would be nice and easy to switch between sounds and the extra effects are a definite plus. So, after setting it up in the 4 cable method as described in the manual, I set up a basic patch with delay, reverb, and overdrive. I set things up so that delay and reverb would route through the effects loop and the overdrive would go through the front of the amp. So far, so good. I then wanted to add external switching to change channels on my Mesa Mini-Rectifier head. Got it all set up and it works but there's a hitch...Every time I switch on the dirty channel on the amp, I get a pop. I've tried different cables, the one that came with the amp and that works fine with the amp's footswitch, a TRS cable, and a standard instrument cable. No changes. It still pops. If I run the HX through the front of the amp it works just fine, no pops. But, who really wants to run delay and reverb through the front of a high gain amp? I've even turned the effects loop off while running through the effects loop and no pops. I'm stumped. I've done lots of google searching and there are no solutions it seems. Am I doing something wrong or is the annoying popping just the way it is with the HX and my Mesa? Any help would be appreciated. Thanks. Quote Link to comment Share on other sites More sharing options...
collinsaj17 Posted January 26, 2019 Share Posted January 26, 2019 I am having the same issue with my Mesa Mark V35 Head and HX Effects. Have you found any solutions yet?? Quote Link to comment Share on other sites More sharing options...
rthirdeye Posted December 27, 2021 Share Posted December 27, 2021 I have the same issue with my Diezel VH-4. I run the 4 cable method and use the midi to switch channels on my amp and it pops when I switch channels and patches very disappointed with this issue. Didn’t have this problem with my TC G-System. Any ideas??? Quote Link to comment Share on other sites More sharing options...
