Problem with working with Canal A and B
sigir
Here are the print-screans: https://cloud-esprit-libre.ovh/index.php/s/Z2Ti6wsFtJcfrYM
 - there is a preset 1 with effects and a amp
 - I copy it to a new empty preset, called 2
 - I drag and drop the effects and the amp on Canal A. Same order.
 - in the mixer : +3db on Canal A, and Pan Pot at the center
But the new preset (2) has a different sound than the original preset (1) : more drive and more bass
If I do the same with Canal B, it's OK... but the tuner don"t work with INPUT 2!
any idea?
Thank you for this article!
But I still doesn't understand since INPUT 1 is set to GUITAR IN and INPUT 2 to AUX IN. Maybe you can't read zip files? Here they are :
(it's the same result with prest 2 with the 2 blue cubes set at the end right
OK, I understand now, i don't understand why, but never mind   :-)
I've put a Studio EQ at the beginning of the path A, with only the gain changed, at -9 dB
And +6 dB in the mixer for path A to have the same volume than presets 01
I don't know why it works with -9 dB, and not -6 dB like you say.
It works for 02B, 02C and 02D.
For the clean sound (02A), I've set -6 dB in the first Studio EQ and only +1.5 dB in the mixer.
And more Lo Freq, and less Hi Freq to have not the same sound but nearly.
I don't understand, but it's OK for me :-)
Thank you !
