purptiger Posted January 19, 2019 Share Posted January 19, 2019 Another 4 cable method posting. I. Am using a Trademark 60 in 4 cable method (Fender HRDlx in shop). I set up amp to my liking. I was able to balance the signal to amp with helix to amp. Then I put a Essex AC 30 preamp in chain by affects S/R. I was not able to balance the volume between preamp model and the amp (turned up return gain did not help). Then use Ac 30 amp and now was able to get close by using channel volume. I did not want to increase drive to raise the volume. The amp without cab sounds good thru the TM 60. Am I on the right path? Any tips? Quote Link to comment Share on other sites More sharing options...
