Jtv-89f Trem Block
The block has a rather large circle drilled out of it to allow the piezo cables to pass through it and into the CPU compartment. I'm not sure if the cables are long enough to be routed around a new block. I suppose an upgraded trem block could also have a large circle machined out of it, but that defeats the purpose of the upgrade.
Very true - I've upgraded to the blocks on my other Floyds and it does make a difference.  But if I have to get a hole drilled in a block to thread the wiring harness or if the trem ends up impinging on the wires in the cavity, then I'm not sure it's worth it.
