The 5 Best Folding Pocket Knives
RubenCarner
You want a pocket knife for security purposes so that you track every single number of tasks to be finished. It might be used to skin an elk or cut fruits from a tree, open packages, or cut a loose string that threatens to unravel the whole sweater. And this knife doesn't have to be complicated or comfortable to carry everywhere. It can go in our pockets along with our phone, wallet, and keys.
Looking primarily at folding knives for everyday-carry knives (EDC), we want something that fits comfortably in the bottom of the pocket. Since they are lightweight and portable, we should have looked at almost only single-blade folders instead of multi-tools like a Leatherman. Due to the lack of fixed blade rigidity on folding knives, we focused primarily on folding knives with the additional security that it does not touch your fingers while you use it.
Another thing you should take into account is that you can handle the knife in many ways, like when slicing or opening particular packages.
The type of metal from which the blade is made is another significant consideration. You should pay more attention to the blade material. We would choose carbon or stainless steel. Carbon steel is easy to sharpen and lasts much longer, but it's easy to become corroded. Stainless steel blade is the most common choice for the best small pocket knives on the market. It is not as robust as carbon, but the blade should be less corrosion-prone by adding chromium. We will guide you into the different classes and features of 5 Best Pocket Knives Reviews s1c4gnJ.gif below.
Kershaw Blur Folding Knife
This Kershaw Blur is a well-built EDC knife manufactured in the United States with high-quality materials and reasonable prices–usually from $45 to $75 depending on the cutting level. It weighs 3.9 ounces has an overall length of 7.875 inches with a 3.375-inch′ blade. It can be categorized as a medium-sized folding knife. This knife gets the most excellent reviews, which is why we include it as one of the best EDC knives. The blur has a nice drop-point blade, and you also have both choice and even a blunt tip for rescue use. There is also the choice of a single or partly tightened edge. The knife has developed something of a cult following among enthusiasts of high-end knives with those following features:
  • Corrosion-resistant, stainless steel blade
  • Lightweight aluminum handle with Trac-Tec grips
  • Easy one-handed opening
  • Reversible pocket clip
Pros:
  • Well-constructed, features quality materials, reasonable price
  • SpeedSafe assisted for quick, one-handed deployment opening
  • Trac-Tec inserts for extra grip
  • Aircraft aluminum handle
  • DLC-coated Sandvik 14C28N stainless steel blade
Cons:
  • Not an aggressive enough finger guard
2. Benchmade 581 Barrage
Another exceptional knife is the Benchmade 581 Barrage, which weighs 5.2 ounces and has an overall length of 8.35 inches with a 3.6-inch blade. We classify this as primarily a tactical knife, but it would also make a superb larger EDC. The Benchmade 581 has a 3.60-inch′ edge that makes it quite big but still extremely handy to manage lots of sensitive or substantial tasks. Just by looking at the Benchmade 581, you can say that it has a firm grip. The plastic and aluminum handle G10 offer a superior and comfortable grip. The G-10 plastic enables you to get a tight, strong grip that will not cause it to slip from your hand, which we understand many people are worried about, mainly when they are moist. One thing about the 581 we discovered that is very interesting is that the bolster covers the pivot. The knife locks up like the whole cup, and with phosphorous bronze washers, the blade moves smoothly as silk. And the tolerances are very narrow on this knife.
Pros
  • Quick opening spring assist
  • Safety lock
Cons:
  • Must remove the handle to adjust the pivot screw
  • Thumb ramp makes it difficult to cut hard materials
3. Spyderco Paramilitary 2
Knife enthusiasts won't need us to say much about the Spyderco Para 2, known as the best folding tactical knife. With an overall length of 8.3 inches, a 3.4-inch blade, 3.75 ounces weight, this is a larger knife, suitable for heavy-duty utilities. The blade is made of capable, excellent steel, which has been usurped by S35VN. This blade is surprisingly simple to sharpen, gives a very nice edge, and can retain a very long working edge. It is also resistant to rust and corrosion with unbelievable, quick, smooth, and consistent deployment. This is a great knife that can be used with gloves and guarantees smooth and easy implementation.
Pros:
  • High-end knife made using the highest-grade materials
  • Durability and quality
  • The clip can open in four ways
  • Nested compression lock
  • Screw-together building
  • G-10 laminate handle
Cons:
  • Hard to open
  • Poor ergonomics for medium-sized hands
  • High price
4. SPYDERCO DRAGONFLY 2
The Spyderco Dragonfly 2 is the king of best small pocket knives. What's so fantastic about it? Well, the devil is in the details, and the Dragonfly 2 packs in a tiny package a lot of meaningful information. Liner-less handles and compact size maintain weight down to 1.20 ounces. It is extremely lightweight. Ergonomically, the brief length is optimized by including a complete 50/50 finger option, which allows you to take four fingertips over the blade to regulate them more thoroughly. This knife contains a blade with full-flat bevels extending throughout the top of the spine. It reduces the drag during cutting and reduces weight overall. It also features an epoxy-filled tissue fiber of G-10, which is stiff, non-slip, and unconstrained to change temperature and chemical substances.
Pros:
  • Compact, superb lightweight, taking up little space in the pocket while still having excellent ergos
  • This knife feels so secure in the hand
  • Very non-threatening to everyone while still being big enough to be incredibly handy
Cons:
  • High price
5. Zero tolerance ZT0350TS
The Zero Tolerance ZT0350TS G10 Folding Tiger Striped Blade has a single-edge blade that guarantees elevated efficiency for flexible tactical use. Most important, this SpeedSafe Zero Tolerance is designed to assist the blade to deploy rapidly with a light shaft and safe folds. The blade is 3.25 inches long, 0.185 inches thick, has a reversible pocket clip from SpeedSafe manual assist for secure opening and locking that makes it simple, safe to open and carry with distinct types of wardrobe. Blade is made of S30V stainless steel and tungsten. The DLC covering is weather-protected.
Pros:
  • Durable finishing on the blade
  • Perfect IMO jimping quantity
  • Grippy g10 handle makes this knife extremely convenient to carry
  • Different pocket clip positions
  • Lifetime warranty
Cons:
  • Weight 5.8 oz, which is heavier than other knives but shouldn't be too much of a problem
✓✓✓ Find More Information: isUCTij.gif Top Best Outdoor Tools
Conclusion:
And that's our list of best Small Pocket Knives. We hope you find our post helpful, and we'll be pleased if you give us your honest opinions about it. Thanks for reading, and we'll see you in our future posts.
