Problem with 1/4" outputs on two guitars setup
Ale-Russo
Hi everyone! Ok, so I have a two guitars setup, with 4 outputs.
Guitar 1 --> Fx return 3 --> Path 1 --> all the FX blocks --> path 1a --> Impulse Response--> XLR panned 100% left. [to FOH]
        --> path 1b --> EQ block --> 1/4" panned 100% left. [to AMP 1 fx return]
Guitar 2 --> Fx return 4 --> Path 2 --> all the FX blocks --> path 2a --> Impulse Response --> XLR panned 100% right. [to FOH]
        --> path 2b --> EQ block --> 1/4" panned 100% right. [to AMP 2 fx return]
Now, the XLR outputs work just fine.
In the 1/4" Outs, boths guitars sound fine, BUT, guitar 1 appears at very low level in AMP 2, and the same with guitar 2, appears at very low level in AMP 1. It's like I'm not able to hard pan left or right on both paths in the 1/4" Outs.
I tried clearing all fx blocks, and going straight to Guitar in, and also going out with FX sends 3 and 4, same thing happens. Guitars just bleed on one anothers path.
Am I missing something?
Thank you very much!!
