Helix HX in fx loop or 4CM Marshall
Adders60
I’m loving the Helix HX and using it in the 4CM with my Marshall DSL100 head I’ve now decided it suits me better than just my FX loop of the amp.
I tried setting up in Snapshot mode ( brilliant idea ) but found getting into this mode too many button presses per new song.
instead and I think better is to use Stomp box mode and name parts such as Solo, boost, Chorus etc etc
when you want a solo delay plus level boost plus perhaps other effects I save all those under the same FS number IE one stomp and numerous effects turn on.
like Snapshots using Stomp box mode you get zero latency changing effects
This works really well using the Kinky Boost in front of my overdrive channel on the Marshall and sounds very very good folks
I also use it to switch channels to clean on my amp,
