fatherjacques Posted August 29, 2019 Share Posted August 29, 2019 Would it be feasible to have a kind of inserts Block like the hardware has within Helix Native. We could use our favorite hardware or softwares etc... within Helix Native. Especially for snapshots. Quote Link to comment Share on other sites More sharing options...
soundog Posted August 29, 2019 Share Posted August 29, 2019 Yes, it would be feasible, and I think its a great idea! I added the idea of "Helix Native Virtual Input/Output Ports" to IdeaScale (where users add and vote for Helix ideas) a couple of years ago after I first started using Helix Native. It seems like a natural fit. The idea has received some votes, but who knows if Line 6 will ever add the feature. You can vote for it here. Quote Link to comment Share on other sites More sharing options...
fatherjacques Posted August 30, 2019 Author Share Posted August 30, 2019 Thanks for the link. Quote Link to comment Share on other sites More sharing options...
craiganderton Posted August 30, 2019 Share Posted August 30, 2019 Meanwhile, there's a workaround of sorts...most DAWs have plug-ins that work with hardware. You could put one Helix in front of it, and one after it. Of course this would work only with serial, not parallel, effects chains. The biggest potential problem is that with Helix Native, to integrate hardware you would need to go out the audio interface, go through the hardware, then loop back into the audio interface. This would likely add a considerable amount of latency with anything other than a Thunderbolt-based audio interface. On mixdown it wouldn't be a problem, but there might be an unacceptable amount of delay when tracking. Quote Link to comment Share on other sites More sharing options...
fatherjacques Posted August 30, 2019 Author Share Posted August 30, 2019 Thanks . I have this once to see how it would go. I think if we could load and other plug-ins within a block of Helix Native then we could use scenes that would incorporate this block. As an example we could use Echoboy from soundtoys or any other plug-ins loaded in a block and place it where we want to. We could probably route an other channel input of our DAW to the block for hardware units. I am not an expert so I don't even know if it would make sense. Quote Link to comment Share on other sites More sharing options...
