ChrisWitoski Posted September 6, 2019 Share Posted September 6, 2019 hey guys does has anyone experienced the 6sw looper playback button operating intermitently ? i use mine several days a week as a solo artist and often the play/ stop button isn't working can it should when i go to stop and start. It gets stuck once in a while when i hit play back it toggles back to stop and sometimes when i hit stop it stops for a second then play again when i release. please help cw Quote Link to comment Share on other sites More sharing options...
Peter Posted September 6, 2019 Share Posted September 6, 2019 Do you have the problem only in looper mode? Maybe you have a general problem with this footswitch? https://line6.com/support/topic/47456-helix-floor-footswitch-failing/?tab=comments#comment-302121 Quote Link to comment Share on other sites More sharing options...
ChrisWitoski Posted September 6, 2019 Author Share Posted September 6, 2019 ya,. its only happening in looper mode on the playback button. i use the function ALOT and gig about 15-20 days a month at 3 -4v hour gigs. wondering if stage grime is affecting its performance, as the problem seems to have started recently. Quote Link to comment Share on other sites More sharing options...
ChrisWitoski Posted September 6, 2019 Author Share Posted September 6, 2019 the "double press" is exactly what is happening, I've only had the unit since april. wondering if i should exchange it as i have 2 year warranty? Quote Link to comment Share on other sites More sharing options...
Peter Posted September 6, 2019 Share Posted September 6, 2019 Have you installed the latest firmware? I think line6 has tried to fix this problem with a bugfix in 2.8 Quote Link to comment Share on other sites More sharing options...
ChrisWitoski Posted September 6, 2019 Author Share Posted September 6, 2019 just did and its still having same issue with "double tap" Quote Link to comment Share on other sites More sharing options...
Peter Posted September 6, 2019 Share Posted September 6, 2019 Then I would open a support ticket or maybe you can ask your dealer for a replacement device. You can clean the switch, but you have to open the Helix. I don't know, if you want to do that in the warranty period. Quote Link to comment Share on other sites More sharing options...
ChrisWitoski Posted September 6, 2019 Author Share Posted September 6, 2019 agreed, thanks for your insight peter! Quote Link to comment Share on other sites More sharing options...
