Helix set up for stereo out to two external amps/cabs
steveinnyc212
Hi All: I'm confused at HELIX FLOOR UNIT signal path and set up for: stereo out to two external amps/w cabs (1 is a tube amp, one is a digital amp, both have efx send/receive on their backs.... wanted to get that stereo efx spread in delays and reverbs left and right panned... can't seem to get it to work.... suggestions would be appreciated....
I tried taking from the 4 and 7 cable method, wanted my fuzz pedal in thee as well as like (send/return.1) but still confused....I had been going into the tube amps "pre amp, back to the helix for efx like delay and reverb, and then back to the tube amps power section for the speaker. I then tried splitting that 1/4" out with a humdinger, and feeding that 1/4" out also to the digital amps fx return in, but that was not particularly effective. it worked with the digital amps guitar in, but I would get occasional popping noises. (yes feeding pre amp to pre amp is not a great idea in the real amp world, but can be done in the Helix to stack pre-amps) I then threw in pedals, first a fave fuzz of mine and a TS8, and tagged on the end of the signal chain a pedal looper and a Trio+ (because why not).... and planned to sent the trio and looper to the second amp... MMMM maybe I'm over reaching.... But I wanted to know how to set up stereo outs for using two external  amps/cabs  and I'll try working from there adding in my pedals and drum pedal and external looper...
