Update Flash Driver Help
dkloss
Need Help.
Haven't used my Pod xt live in some time and want to update. Once in the Monkey and Line Six Edit, I can't update the driver, like it tells me I need to do. Says I'm not connected to the internet, but I am. Monkey says Check for updates, but get unrecognized file message 80001019. Tried to update driver, get HTTP 404 Not found message. Driver not installed? How did I use it before two year hiatus from Line Six?
Any help for me? Or do I just put this product back in the box and go back to using my pedals. (Why I took a two year hiatus from line six in the first place, too cumbersome it seems.)
If your having troubles with Monkey, you can bypass it by downloading the driver
from the support pages within this site and manually install them yourself.
Also note, that when you are installing this driver, you should exit both
Monkey and Edit before proceeding as to ensure a successful installation.
As for why its doing that, it may be that your firewall or security
software blocking Monkey's access to the internet. Hope this helps.
http://line6.com/software/
