FraserClark1 Posted October 20, 2019 Share Posted October 20, 2019 Hi, I need a bit of help! My AMPLIFi 75 used to work perfectly however the three buttons on the top face of the amp do not work. The ‘ABCD’ lights do not change when the Button is pressed and neither does the patch. The Bluetooth light does also not illuminate and the amp does not appear on Bluetooth. I’ve tried all sorts, every vacuuming around the buttons in case any dust found its way in there but no luck.. can anyone help? cheers Quote Link to comment Share on other sites More sharing options...
tronak Posted July 19, 2020 Share Posted July 19, 2020 Hi, I have EXACTLY the same problem. Did you fix it? Anyone can help? Quote Link to comment Share on other sites More sharing options...
hmegaly8090 Posted August 1, 2020 Share Posted August 1, 2020 I hope you guys managed to fix it. Quote Link to comment Share on other sites More sharing options...
tronak Posted August 3, 2020 Share Posted August 3, 2020 Not me :( The only way for me is taking the gear to a repair bussiness. Wich I will not do... I anyone wants to try, in this thread you can find two different solutions: I tried replacing the SD memory card, but it was useless. The other solution is to replace a RAM memory module, wich could be the solution, or not. Nobody knows... But it appers to be hard to do it correctly. This family of products are not available anymore, and it´s for something.... Quote Link to comment Share on other sites More sharing options...
