dannyvega Posted January 6, 2020 Share Posted January 6, 2020 I thought I'd post my fix to my used Bass Pod XT. Under Windows 10, I did a firmware update and a flash memory update to the latest versions and after the updates, the Select Page, Effect Tweak, Amp Models, and Effects rotary encoder knobs all ceased working. All of the other knobs and buttons seemed to work but these 4 rotary encoder knobs didn't. I tried updating the firmware and flash memory in safe mode as well (hold down the first soft key and power up) and that didn't fix it. I did an SRAM check (hold down the second soft key and power up) and it reported that memory passed. So I took a wild guess and tried holding down the fourth soft key and power up. It went through some kind of diagnostic ending with an LCD test whereby it tested all of the pixels in the LCD screen. After that test, I power cycled the unit and lo and behold, the rotary encoder knobs now were functioning. I hope this helps all of you Bass Pod XT users that have experienced the same problem. Quote Link to comment Share on other sites More sharing options...
